Under hood fan trouble.
Old Mar 16, 2014 | 05:15 PM
BeefSS's Avatar
Default Under hood fan trouble.
In my '05 SS I have notice that my car was slowly over heating when sitting steal. I was told it was the Thermostat so I replaced it today 3/16/2014 and after letting the car sit and run for a few the same problem started again. So I started looking and saw my fans were not turning. I cut on the a/c in my car and they still didn't respond I checked all fuses in car and under hood none was blown am I missing something or did I really lose both fans at the same time?.
Old Mar 16, 2014 | 05:20 PM
It maybe a fan relay ? you can unplug an test your fans with a hot wire an a ground wire to see if they work ..
Old Mar 16, 2014 | 05:21 PM
BeefSS's Avatar
Originally Posted by zjerry
It maybe a fan relay ? you can test your fans with a hot wire an a ground wire to see if they work ..
Ok I'm going to try rite now
Old Mar 16, 2014 | 05:31 PM
BeefSS's Avatar
OMG! That worked so how do I fix this?
Old Mar 17, 2014 | 07:59 AM
You just replace the relays
Old Mar 17, 2014 | 10:04 AM
BeefSS's Avatar
I am about to order all 3. I'm wishing for the best
Old Mar 17, 2014 | 10:22 AM
Maybe,
Its just dirty connections?
Try plugging and un plugging it a cpl times.... Maybe you'll get lucky?
Old Mar 18, 2014 | 06:35 PM
jakefluker's Avatar
Go with the good relays,they aren't much so pay the extra price and keep extra on hand just in case of future prob.
Old Mar 20, 2014 | 03:09 PM
BeefSS's Avatar
I just out all new relays in samething well they came on for a sec and went back off
Old Mar 20, 2014 | 03:10 PM
BeefSS's Avatar
Originally Posted by STUMPMI
Maybe,
tried that no dice
