Under hood fan trouble.
In my '05 SS I have notice that my car was slowly over heating when sitting steal. I was told it was the Thermostat so I replaced it today 3/16/2014 and after letting the car sit and run for a few the same problem started again. So I started looking and saw my fans were not turning. I cut on the a/c in my car and they still didn't respond I checked all fuses in car and under hood none was blown am I missing something or did I really lose both fans at the same time?.:confused:
It maybe a fan relay ? you can unplug an test your fans with a hot wire an a ground wire to see if they work ..
Originally Posted by zjerry
(Post 603949)
It maybe a fan relay ? you can test your fans with a hot wire an a ground wire to see if they work ..
(Post 603949)
You just replace the relays :thumbsup:
(Post 604043)
Maybe,
Its just dirty connections? Try plugging and un plugging it a cpl times.... Maybe you'll get lucky?:thumbsup: |
Go with the good relays,they aren't much so pay the extra price and keep extra on hand just in case of future prob.
Originally Posted by jakefluker
(Post 604337)
Originally Posted by STUMPMI
(Post 604061)
Maybe,
