Opinion Needed: Twin turbo build need help
Old May 1, 2021 | 12:18 AM
Repent's Avatar
Default Twin turbo build need help
Can I use a saab 9-3 2.8 v6 turbo, it as two exhaust inlets so I thought of just covering one with a steel plate and running it with the single inlet or do I run a pipe from one header into one side and a pipe from the other header into the other side? Or will I have to get the 2.0 version with the single inlet, reason being is theres abundance of saabs at a local junkyard and I can get the turbos for 80 bucks a peice. Also finding piping isnt an issue I have a buddy who can make anything I need.
Throwin them on a 3.8 that im rebuilding with perf parts. The engine is going in a 99 3.1 monte that im swapping
BrandonStebing
Jul 13, 2014 07:42 PM
turbo monte
Sep 14, 2012 04:53 PM
nick_
19
May 4, 2012 09:20 PM
hard2top
Nov 29, 2010 12:12 PM
Wilco
Nov 21, 2009 02:11 AM
