6th Gen ('00-'05): turn sinals
Old Oct 3, 2015 | 11:15 AM
scottschevy72's Avatar
Default turn sinals
New problem.. hope someone help me.. my turn signals messed up. I have changed hazard switch 2 times still no good. Everything works fine until I move shifter out of park. Then turn signals flash real fast. All bulbs good.any help would be great.. thanks scott
Old Oct 3, 2015 | 12:20 PM
RickCoMatic's Avatar
When my flashers went, ... they WOULDN'T flash unless I hit the Emergency Flasher Switch to goose the Flasher Element. Since the system relies on the Flasher Element of the Emergency Flasher Switch/Module ... I say you look there, first.
Old Oct 3, 2015 | 12:28 PM
Have changed that switch 2 times with no fix, got 2 new switches from 2 different new parts sales. Everything works perfect until I move my shifter out of park. Then the turn signals mess up until I turn car off and take key out. Put key back in, start car, everything works perfectly , move shifter and messes up all over again.
Old Oct 11, 2015 | 06:09 PM
I saw your response in another post and this link may also help with the issues you are having--->https://montecarloforum.com/forum/mo...t=turn+signals
Old Oct 11, 2015 | 06:34 PM
plumbob's Avatar
Scott the problem could be the connector to the hazard flasher or a bad ground connection. With the instrument panel removed try wiggling the wires to see if it has any effect. Odds are it's a common ground wired sharing the same circuit as the gear indicator.
