turn signal cam?
Old Feb 1, 2011 | 11:09 PM
berencam's Avatar
Default turn signal cam?
Does the 2000 monte carlo have a signal cam in the steering column, or is it a part of the turn signal lever assy?
Old Feb 2, 2011 | 09:44 AM
JaxJim's Avatar
Old Feb 2, 2011 | 03:06 PM
berencam's Avatar
do you think it would be 3 or 5 that would cause the turn signal not to center when you turn the wheel the opposite way of the signal?
Old Feb 2, 2011 | 08:50 PM
JaxJim's Avatar
Well, it would have to be either part 10, the cancel cam/ signal cam or part 3, the combo switch. The cancel cam is about $5. The combo switch assembly lists for $544.78 - but is discounted to $283.29 on gmpartsdirect.com. Without pulling the column apart, I don't know if you could tell which part is bad. I fear it might be the combo switch, however, as that has alot of moving parts. The cancel cam is just one molded piece of plastic.
Part 5 is a an electrical connector that would not cause the issue you describe.
These parts may also be available from non-GM suppliers through the various discount auto parts stores - O'reilly, Advanced, AutoZone, etc.
Old Feb 2, 2011 | 09:46 PM
berencam's Avatar
Im used to my 70 c10 that has alltogether about 7 parts for the entire column. i didnt notice the signal cam in the diagram. ill check it tomorrow.
Old Feb 3, 2011 | 08:21 AM
JaxJim's Avatar
It's a pain in the *** getting at those parts because of all the c-clips and because you need special tools to pull the wheel and compress various springs. Hopefully you have the tools needed. If not, they are cheap to buy. It's also possible that the various discount auto parts stores may loan the tools for free.
trey0503
Apr 27, 2018 11:39 AM
JoeD
Jul 15, 2014 10:00 PM
NYGiantsfan
Jun 19, 2014 12:30 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
