t's HOT i n Texas @$%!^#@(*^&#$ I
I see you have a CT turbo, do you also have the IC installed? If you do, did you remove the lip at the bottom of the front fender? That piece draws air to the radiator and helps cool it. The IC isn't too restrictive but in the middle day, when temps are 100 and up, it's not going to aid the radiator stay cooler either. The kit comes with a 180 thermostat and the dp comes without the U-bend. You may also want to have your PCM tuned so the fans come on at a lower temperature, and like the previous poster mention, stay on for a minute after you stop the car.
It's just really hot here right now. Like the hottest summer on record and we are in exceptional drought.
drought austin - Google Search
Hey,,, at least it's not muggy right now.
Practicing rain dance soon.
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
A few things you can do, such as a colder thermostat (160 or 180 degrees, up to you) it sends coolant through your system at a lower temperature (stock is normally 195). If you are forced induction you can get colder spark plugs, such as copperlite 605's or copperlite 104's. You can get cold air, which will give you better fuel economy and more horsepower (hardly noticeable). You can get a less restrictive exhaust (think U-bend delete) so that the engine doesn't have to work as hard to get rid of the gases, which will also increase horsepower. You can get a tune that leaves the fans running for a minute or so after you turn off you car. You could also get an IC but that is definitely on the extreme side.
Other answers in other responses.
did that. took it off. going back to it.
Yep IC and no the bottom lip is there. Changed the fans to come on at 175 and the thermostat is a 160. Also fans run after shutdown but I would have to look to see how long.
Practicing rain dance soon.![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
If you have any luck, come by San Antonio and do your rain dance!
![Big Grin](https://montecarloforum.com/forum/images/smilies/biggrin.gif)
Anyway,
You could also try a different mix of coolant and water (if you haven't done so already); say 70% coolant and 30% water instead of 50% coolant and 50% water for example. Good Luck and stay cool!
