FAQ: Trunk Button Failure
Old Jan 2, 2020 | 06:14 PM
Karenski's Avatar
Question Trunk Button Failure
It's not the FOB, that still makes the rear lights flash, just won't unlatch the trunk, nor does the dash button. Hooray for keys! For awhile it said it was open when it wasn't, then this. Is there a fuse I can replace, or am I dealing with a broken wire? Some electrical tape is loose, I can see one strand and one strand only not connected, the others the tape is around are.
Old Jan 2, 2020 | 08:06 PM
Jeffs02rwdSS's Avatar
Best bet it to take a picture and post so we can see which wires they might be .
Old Jan 2, 2020 | 11:48 PM
Karenski's Avatar
Ok, thank you! I'll do it tomorrow when I have some daylight.
Old Jan 4, 2020 | 11:53 AM
Herman Munster's Avatar
Hi my car is a 2001 and I am having the same problem . Does anyone know why the trunk does not open ? It's like the actuator is not getting message ? Something worn out or died ? Herman
Old Jan 5, 2020 | 02:37 AM
xpage's Avatar
my guess is it needs lubrication for the joint/spring/lock area. Spray bottle lithium grease, after getting rid of the old gunk that may be in there
Old Jan 5, 2020 | 10:45 AM
I really think it's the actuator . I'll try spraying it with some lube but the part itself is clean and no gunk present so maybe dry . Herman
Old Jan 5, 2020 | 01:42 PM
My son in law had an issue with his a few years ago and i think he indicated it was in the wiring, his cracked and broke loose in the trunk.
I would check the fuse, then trace the wire back tot he trunk and see if it has a break. the spot could be in the trunk or along the floor trim channel leading to the rear of the car.
Just Call Me Monte
Dec 30, 2014 11:27 AM
avendo
Nov 26, 2014 04:52 PM
iMSeRiOuS
May 3, 2010 01:27 PM
mavrickf1613
Sep 22, 2009 02:08 PM
fastback4
Jan 13, 2007 08:42 PM
