Transmission Problems
Old May 15, 2015 | 08:52 AM
AHart87's Avatar
Default Transmission Problems
I found out that it was bad gas that caused my 2004 Monte Carlo to rev up while driving at constant speed on flat ground. But along the way I found the P1811 code which is the long shift I have experienced in going mainly from first to second and second to third gear. So I guess my transmission is going to go out eventually Can someone tell me how much a new tranny will cost?
Old May 15, 2015 | 09:12 AM
You could just need the solenoids replaced, which isn't an awful job. Mix that with a pan drop and fluid/filter change and you could be good to go!
MillerMonteSS
Oct 14, 2010 10:09 AM
yeyeee01
Mar 3, 2010 10:00 AM
dfell2222
Apr 17, 2008 12:51 PM
idalis
Jan 23, 2008 03:42 PM
Yellow_Monte
Dec 6, 2006 11:02 PM
