transmission kicks hard each shift
Old May 5, 2011 | 02:19 PM
1998 z34's Avatar
Default transmission kicks hard each shift
so today i felt a hard shift so i check the fluid it was low so i added some. When i start driving its fine but after 5 min or so it starts to shift hard agin. Any ideas. thankyou.
Old May 5, 2011 | 05:46 PM
zipper's Avatar
Was the fluid low again?
Old May 5, 2011 | 08:42 PM
1998 z34's Avatar
no its staying at a good level no leaks
Old May 6, 2011 | 05:43 AM
BlownUptoHigh's Avatar
you check your motor brackets seen if there worn may cause your engine to rock and give you the kicked in the rear feeling when accelerating/decelerating. You might need to replace the two on top and 1 on the bottom.
I just had the top two replace and while the long shifts are still happen occasionally the car doesnt jerk anymore while doing it.
Old May 6, 2011 | 10:10 AM
nitehawkjcb's Avatar
Scan the PCM for transmission faults. You probably have solenoids going bad that are causing your issue. Change the fluid and filter, that may solve your issue. Otherwise, you going to have to pull the tranny and change those solenoids.
Old May 6, 2011 | 11:40 AM
1998 z34's Avatar
thanks im going take it to my shop to get it scanned i checked the brackets there good thanks for the help.
gkathleenw
Feb 29, 2012 11:03 AM
Bruce All-Monte
Jul 14, 2011 07:28 AM
JaxJim
Dec 22, 2010 12:11 PM
Absolutpolack
Dec 14, 2009 10:02 PM
Absolutpolack
Jun 25, 2009 12:15 AM
