abs always kicks in
Old Jun 24, 2009 | 11:28 AM
Absolutpolack's Avatar
Default abs always kicks in
When Im driving over 20mph and I use the brakes to slow down it feels like the abs kicks in (shuddering/skipping/vibration in the pedal and car). The traction control also sometimes comes on when it definetely shouldnt and also at times it randomly fails and I get the service traction system light and the abs warning light. The previous owner said that he bought cheaper rotors so they heat up faster and cause the vibrations, but thats not it. This happens right away with barely any warm up time. Need new sensors? New breaks?
Old Jun 24, 2009 | 11:36 AM
RickAKATed10's Avatar
Photobucket
Could be sensors.... Take it to get the codes read when they turn on next time.
Old Jun 24, 2009 | 12:05 PM
labnjab's Avatar
Sounds like a faulty wheel speed sensor and is a very common problem on gm's. The thing that sucks about abs is sometimes when theres a problem, theres not always codes. If you have access to a tech 2 I'd watch the wheel speed sensors on data while someone else is driving and find out which wheel reads 0 before the others while stopping. The one that does is the bad sensor
Old Jun 24, 2009 | 01:20 PM
Budsjlm's Avatar
pull of the wheels n check where the sensor reads from any of those ribs r cloged they will give you issues
Old Jun 24, 2009 | 02:13 PM
All wheels or just front?
Old Jun 25, 2009 | 12:15 AM
Budsjlm's Avatar
to be safe if u have 4 wheel abs which i asume u do id do all 4
sisson16
Feb 21, 2012 04:28 PM
M.C.BOB
Jun 22, 2011 02:10 PM
1998 z34
May 6, 2011 11:40 AM
xjcurtisx
Jun 25, 2010 11:13 PM
Absolutpolack
Dec 14, 2009 10:02 PM
