Opinion Needed: Transmission help
Old Apr 6, 2015 | 02:41 AM
Dan626's Avatar
Default Transmission help
So after a blown transmission, I swapped my factory transmission with a junkyard one. Transmission works great. No harsh shifting or slippage. Everything seems fine. I am concerned about the trans pan though. The junkyards like replace the bolt to empty trans fluid with a plastic cap. The cap is in there very tight but I am concerned it may pop out while I'm driving and I will lose all of my transmission fluid. Is it ok to keep it there or should I replace the trans pan to the factory bolt? Any advice is much appreciated. Thank you in advance.
reaper18769
Aug 3, 2010 10:52 AM
K-Mac Attack
15
Jan 21, 2010 11:12 PM
MyIntimidator
Nov 6, 2007 08:44 PM
mm12678
Nov 1, 2007 09:22 PM
Yellow_Monte
Dec 6, 2006 11:02 PM
