trans problem
Old May 26, 2020 | 08:06 PM
John Gehling's Avatar
Default trans problem
i changed my front hubs and now it wont start unless i have the gas is pressed and then it idels hign about 2000 and when i shifi
t into gear it almost stalls n it wont come out of first gear(low) any help is appreitaed didnt do this before i changed the hubs oh i also changed the plugs
Old May 26, 2020 | 08:08 PM
ohiforgot it is a 2002 dale er.ss
Old May 27, 2020 | 03:13 PM
Doesnt sound like a trans problem. If you start it up in park and it idles way high and requires throttle to keep alive, something else is wrong.
The hub change would be unrelated, but the spark plug change could be or it could just be bad luck. Are you sure you sure none of the plug wires got damaged during removal? Are you sure none of the new plugs have cracked ceramic? Gaps all ok? Did you unplug / disconnect anything else?
mc1978
33
Apr 21, 2015 10:26 AM
vikesfan
13
Oct 23, 2012 08:15 AM
Ice7891
Feb 25, 2011 07:29 PM
GSteve51
Nov 4, 2010 02:43 PM
04intimidatorssjmm
Aug 24, 2010 09:09 PM
