tranny leak
Old Apr 11, 2009 | 12:30 PM
chevyrider08's Avatar
Default tranny leak
well got bad news today...took my baby for his oil change...n found out i got a tranny leak...any ideas where?...any info i can provide for help?...plz help guys really need ya'll
Old Apr 11, 2009 | 02:54 PM
Hi `Eric,
Sorry 2 read about your problem : (
I could be a SmartAzz & say it's leaking from your
transmission : ), but I shall refrain.
What did the tech say @ the oil change location ?
What year/model/engine do you have ?
How low was your transmission fluid ?
(Check it when warm & Monte on level)
Is tranmission slip'in or acting strange ?
Post how it is shifting.
Look 4-ward 2 your answers, and hopefully one of
our expert tech members can share their knowledge,
suggesstions.'
Good Luck
Old Apr 12, 2009 | 12:48 PM
transmission had a leak...he didnt mention how much had actually leaked already...i have a 02' 3400 montecarlo....to me i havent notice any change in automatic shifting...still smooth i think its just a classic gasket leak...any ideas?
Old Apr 12, 2009 | 02:55 PM
`Eric, I suggest that you have a mechanic check it `out if you can't.
A gasket for a transmission pan, is way far less $'s,
then a rebuilt transmission. 4-Sure!!!
I also suggest that you keep checking your transmission
fluid level, until you know that the leak has been fixed.
It is to difficult to attempt to evaluate the location of
your leark on your 3.4L without a personal inspection.
Wish you good luck, and no leaks.
Old Apr 15, 2009 | 06:00 PM
montecarlossfan's Avatar
first of all..make sure fluid is at proper level, then wash the engine bay, and under the car ..and over the next week or so look for the leak.., if its the pan gasket , easy fix, if its a seal where your cv axles go, easy fix...if its leakin where the torque converter seal is it is a lil more involved, but fixable
DerrtyD
Jul 14, 2015 05:33 PM
mrjaysc
Aug 25, 2013 08:56 AM
04IntimidatorSS
Dec 3, 2012 07:59 AM
slinkeey
Feb 3, 2009 10:33 AM
adryan16
Sep 9, 2007 05:47 PM
