traction control
Old Dec 5, 2010 | 02:23 PM
goingforgold's Avatar
Default traction control
When I turn the wheel left from a stop and gas it the traction control comes on for just a second then goes off. This only does it turning left. I have an 02 monte. Has anyone had this same problem? Could it be a wiring problem in the right wheel?
Old Dec 5, 2010 | 02:53 PM
do you slide when you turn left or accelerate a lot? it sounds like just a wiring or sensor fault to me
Old Dec 5, 2010 | 03:19 PM
no sliding I'm on dry pavement. It's when I pull out of my carport and turn left and accelerate.
Old Dec 31, 2010 | 02:26 AM
chivalry's Avatar
I have a similar problem with my 02 monte SS. Sometimes if i crank the wheel pretty far when parking or whatever, the traction cntrl off light, check engine light and brakes light all come on at once, with a message to service traction control. After a while it will go out, or at least after the car is shut off and restarted. There is never any kind of driveability issue though, when these lights are on.
Old Jan 2, 2011 | 07:45 PM
I had a similar problem with my wife's 2005 impala ss ,I replaced both front hubs light still on . it was the wire from the side of engine to the abs sensor ,replaced wire the problem gone over 4 months now.
Old Jan 3, 2011 | 04:07 AM
chivalry's Avatar
Wow, that had to have been frustraiting! Its great that you got it all squared away. Thanks for the insight!!!
Old Jan 3, 2011 | 04:09 AM
chivalry's Avatar
What all was involved inorder to replace the wire? Was it an entire harness? And if so, what was the name or part # ? Im really not experianced with electronics on modern cars, LoL! Im much beter at working on my 67 impala. Thank you for your help!
Old Jan 3, 2011 | 12:49 PM
I got abs sensor harness on ebay . the harness is about 3 or 4 feet long, goes from sensor to the side of engine , I soldered the wires together
Old Jan 5, 2011 | 03:15 PM
edg4014's Avatar
Default my brakes, abs and trac control
when i break sometimes my break paddle pushes back with a clicking noise now my abs light and trac control turns off so does this mean i need to change the wires also
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
Jul 8, 2012 08:27 AM
willysmith
Mar 16, 2006 07:50 PM
Bob50th
Jan 7, 2006 09:46 AM
