trac off abs
Old Mar 10, 2008 | 09:02 AM
willie8701's Avatar
Default trac off abs
what would cause the service trac light and the abs light when braking somtimes it is like the key was turned off it is a 2001 monte help please.....
Old Mar 10, 2008 | 09:13 AM
Default RE: trac off abs
Hi `Willie, from Cincinnati.
Have you checked your brake fluid level ?
It also could be a sensor ?
Is it throwing any codes ?
How many miles are on your Monte ?
Be Patience, and I'm sure our expert member's will
post more information/solution.
Some part stores, will do a code check for you for free.'
Good Luck,
`Space
Old Mar 10, 2008 | 09:42 AM
willie8701's Avatar
just turned 70,000 miles it is a ls
Old Mar 10, 2008 | 12:02 PM
Hi again `Willie,
Did you check your brake fluid ?
Did you call your local parts store & see `if they will
test your system for codes ?
Be `Patience, & hopefully a member with answer.
Good Luck
teamfbody
34
Aug 11, 2013 08:22 PM
Jokers1995
Jul 31, 2012 09:11 AM
Franks 03SS
Jun 1, 2012 08:10 AM
asmart82
Mar 5, 2012 06:35 PM
