trac control will not dissengage
Old Nov 15, 2006 | 04:54 PM
spike_monte's Avatar
Default trac control will not dissengage
about a month ago, me and some buddies were breaking in my monte. just smoke shows and messing around. one of my buddies blew up his 94 talon..it was fun, obviouselly. i was wondering if anyone else has had problems with their traction control always being engaged? i press the button and it says that it is off, is there anything i can do? it is annoying when i want to go have some fun in my car, it will still smoke em, but it revs and drops, revs and drops...doesnt sound or look as good as it could
thanks for any advice
Old Nov 19, 2006 | 02:57 PM
wickedmontess's Avatar
Default RE: trac control will not dissengage
When you say revs and drops are you talking about trying to power brake? If so the newer computers will cut power if you try that. If you just wanna blow em up hit the gas with the E-brake on. Either way burnouts are highly suggested against. My brother has a 2000 GTP we just did an engine and tranny swap on. The looks of that tranny from all his burnouts was nasty. Besides it doesnt matter who can the best burnout, Its whose car will hook and smoke em. but anyways give me a little more specifics and we will see if it can be figures out.
Old Nov 21, 2006 | 07:25 PM
Backinblack's Avatar
I got stuck in the snow and was trying to rock the car out. Even after turning off the trac control...the motor would rev and drop off like you described. It was explained to me that the computer senses the difference between the front wheels spinning and the rears not moving much through the wheel sensors mounted front and rear. The computer then cuts power because of this. I don't know if this is the actual cause but it made sense and it was'nt fun getting the car unstuck because of it!
Old Nov 22, 2006 | 09:38 PM
ok..note to self..do not mess around with my car..gotcha!
thanks for the help. ya thats what i meant..RPM's would just drop and climb again, i was just wondering if it was something wrong with my trac control or something else..now i see i cant do anything about it
thanks again
lonerider
Feb 4, 2014 06:22 AM
ladagosta
Aug 24, 2012 09:54 AM
That Cool Aunt Debbie Chick
Aug 21, 2012 05:46 AM
ladderman100
Jun 3, 2010 09:26 AM
wht02monte
Feb 10, 2010 01:12 PM
