ABS/Trac Control Issues
Old Aug 21, 2012 | 04:15 AM
That Cool Aunt Debbie Chick's Avatar
Default ABS/Trac Control Issues
2002 Monte SS, ABS & Trac off lights are on, A Matco Scantool identifies a bad right rear wheel speed sensor.
Last Saturday, an inspection reveals the sensor is molded or pressed into the hub, with no mounting bolt like used on ABS sensors on other cars, I removed the brake rotor, and the 4 bolts mounting the hub to the axle, but could not remove it, how do you replace the right rear hub?
Old Aug 21, 2012 | 05:46 AM
They can be very tough to remove from that point. It's basically corrosion holding it on now.
I used a nice big hammer with PBlaster and whacked it a ton. I know some people use air tools and an air hammer to knock it out.
American_Muscle
Jun 1, 2015 08:48 PM
Musicman217
Nov 30, 2014 09:35 AM
peterjwsong
Feb 24, 2014 06:52 AM
lonerider
Jan 12, 2014 12:28 PM
ladagosta
Aug 24, 2012 09:54 AM
