6th Gen ('00-'05): trac control abs
Old Jan 10, 2014 | 03:40 PM
lonerider's Avatar
Default trac control abs
help not shore, what to do .... my trac control service light and abs came on .thinking that my brakes need service or pads replace, Is this so ,or something else wrong
Old Jan 10, 2014 | 03:58 PM
Monte_Man04's Avatar
You may have a bad wheel-speed sensor inside your hub. There is a connector that could have simply come loose.
If you didn't curb anything HARD, then that's probably it. How old are your hubs?
Old Jan 10, 2014 | 04:08 PM
lonerider's Avatar
don t know did hear the wear inicator on the front
Old Jan 10, 2014 | 06:45 PM
vikesfan's Avatar
check your frame ground wire under your intake filter
Old Jan 10, 2014 | 09:34 PM
lonerider's Avatar
is this ground wire something ...that happen to u ....or is this a tech.knowledge ?
Old Jan 12, 2014 | 12:28 PM
vikesfan's Avatar
personal experience.
i was having intermittent abs and trac control light issues. checked everything that was suggested and replaced a lot of stuff.
one evening after searching the web for about 2 hours, i came across 1 single post from someone that said to check the ground wire that is under the intake and grounded to the frame there.
so i came out started the car, got the warning, shut it off, took off ground and cleaned the area and sanded a nice shiny surface on both, reconnected the wire and have not had a problem since. that was 6 mths ago.
American_Muscle
Jun 1, 2015 08:48 PM
Musicman217
Nov 30, 2014 09:35 AM
ladagosta
Aug 24, 2012 09:54 AM
That Cool Aunt Debbie Chick
Aug 21, 2012 05:46 AM
willie8701
Mar 10, 2008 12:02 PM
