6th Gen ('00-'05): Too Much Power?
I agree, a working engine swapped from one car to another, you should not need to break it in. Now, if the engine was torn completely down and rebuilt fresh from the ground up, different story.
I would suggest having the oil and oil filter changed on the engine before driving it around.
Sounds to me like you had some bad luck. For all you know, the previous own of that engine may have been driving it hard.
As for the tune, I don't know much about ZZP's tunes, but I would figure for a stock engine, their tunes should be safe and reliable (they have been in the 3800 market for a LONG time).
I hope you get this resolved and no more issues.
So on an unrelated or maybe related matter? I noticed the oil pressure gauge is going haywire and sometimes spinning around completely 360º. Does GM have problems with the stepper motors in the clusters on the '05 Supercharged SS? Its the only gauge to have a problem on the entire cluster OR is it the sending unit down by the passenger tire? I'm also curious there is no way this could have caused an issue with that engine is there? Like if maybe the computer thought there was an erroneous oil pressure level because of the sending unit (if that's the culprit)? I'm reading where if that sending unit goes bad it can throw the engine into a "limp" mode?
Thanks guys I'll have them swapped out. I knew the 05' Trailblazer had problems but I never had problems with my '01 SS so I wasn't sure the stepper motor was the culprit.
The plot actually thickens and I didn't post this initially but the guy originally said "Oh you broke the crankshaft in half"....I was like WHAT?!?! How did that happen? Which I subsequently found out to be a lie since there is no way oil would get on the external side of the engine with a broke crankshaft not to mention that its damn near impossible to do so. My buddy said there is an off chance I threw a rod and it went through the crank case and that "might" have broken the crankshaft, but he flat out said "The guy is lying to you".
Certainly a broken crank could've cracked the block and cause oil to spew out. A broken rod taking out the crank is definitely another possibility, but as the power level is pretty low, it likely started at something like a spun bearing or something - a manufacturing flaw severe enough to break big parts like that would've surfaced before 60k+ miles.
I'd just chalk it up to bad luck, that's part of the gamble with junkyard engines. You're just lucky it died under warranty.
I woudnt get worried about them lying to you about the cause. As long as they're honoring the warranty, it could've choked to death on pixie dust for all that matters.
So the plot thickens: I learned tonight that I definitely threw a rod through the block by the starter and that is what caused the fire. I also was told by the new owner "some things happened during the installation of this engine that weren't done correctly". When I asked him what he meant he said "the flex plate bolts were left loose" and he thinks (my friend said no thinking about it it absolutely) put the engine out of balance and that is what threw the rod through the block. So needless to say I'm a little p!ssed.....
rgant_19
24
Aug 17, 2011 10:42 AM
ltrain925
Dec 22, 2009 11:39 AM
