Tire Pressure Monitoring Maintenance
Old Jan 8, 2007 | 09:58 AM
Default Tire Pressure Monitoring Maintenance
Pat Goss
Tire pressure monitoring systems are a great safety feature on cars. But sooner or later you'll need to have that system serviced or at least the tires and wheels serviced, and that means that you need a shop that understands the system and has the right equipment. To explain some of the things that you need to look for we have Kevin Rohlwing of the Tire Industry Association.
We have a couple of different types of sensors that are used in these systems can you explain them to us?
KEVIN ROHLWING: "There are two types of sensors that are used for tire pressure monitoring systems in original equipment vehicles. One is an actual valve-stem sensor where the transmitter itself is attached to the valve-stem either permanently or with a torque-screw. The other is a band-mounted sensor where the sensor is attached to the center drop of the wheel using a strap or a band."
So band-mounted - are these only after-market?
ROHLWING: "No, actually there are some new vehicles right now that do have band-mounted systems as original equipment fitments, particularly in some of the Ford products."
So band-mounted and up in here we can see the valve-stem unit. Now either one of these can be damaged if the technician doesn't follow procedure?
ROHLWING: "Definitely. Positioning of the valve-stem sensor is critical for both demounting and mounting. If it's not positioned in the proper place, when the bead itself drops into the drop center to demount or mount the tire, it will pin the sensor up against the rim and break it off."
Alright, we can see the bead down here and when this comes down over the edge of the wheel, down into the drop center, tremendous amounts of force here. So ...
ROHLWING: "Absolutely, particularly when you get into the larger size tire with higher rim diameters and smaller aspect ratios."
Got to be done right. Okay, now what's another problem that consumers might run into?
ROHLWING: "One other issue that we are finding really popular in the aftermarket is using the proper valve-core. Valve-stem sensors require a nickel-plated valve-core. Using the improper valve-core, such as a standard brass valve-core can actually cause it to seize inside the valve-stem and you will actually break the valve-stem when you try to remove the valve-core."
So you would have to replace the sensor?
ROHLWING: "Absolutely."
All right what about the caps? They're special too.
ROHLWING: "Caps have to have a rubber O-ring seal up in the base. And that acts as a primary seal and a secondary seal to the valve-stem itself."
Now on some cars there's going to be a need to re-program the system following any type of service. So that means some special equipment.
ROHLWING: "Definitely. Depending on the make and model of the vehicle it's going to require a re-learn or re-calibration procedure. Having the proper scan tools with the updated software is going to insure the TPMS is monitoring the tires after the tires have been replaced or repaired or rotated."
Okay, now what about disabling these systems?
ROHLWING: "It is against Federal law to disable a tire pressure monitoring system and substitute either a rubber snap-in valve-stem for a valve-stem sensor or a band-mounted system." SpaceRider, Don't `F with your wheels : )
Now, but that only applies to the originally equipment wheels. It doesn't apply to after-market.
ROHLWING: "That's correct. If the after-market wheel will not accommodate the valve-stem sensor because of a difference in the contour of the rim then it doesn't have to be installed."
[hr]
If you have a question or comment, write to me.
The address is MotorWeek, Owings Mills, MD, 21
Old Jan 8, 2007 | 10:52 AM
mickey's Avatar
Default RE: Tire Pressure Monitoring Maintenance
well if this helps ya any i just did my tires today and i know that on the 03 or atleast my car i dont have the one inside the tire. btu then i didnt see the one on the spindal either. Next time i have it in the air i will check to see if i can find it.
but i would liek to know that if i were to put the steel valve stems in to the stock wheels if it would still ahve a isue with it.
AAGL
Apr 19, 2014 09:43 AM
Facekicker
Oct 28, 2013 10:10 AM
Jun 21, 2010 01:04 PM
BeachBumMike
Feb 21, 2008 06:11 AM
Greeny
Oct 30, 2006 11:50 PM
