time out reset
Old Nov 30, 2011 | 08:31 PM
chase2001's Avatar
Default time out reset
Im told after i reset the bypass lock,,with a key,,in the on pos for ten min or so,,and the car starts back up,,Im only putting it on time out,,Does anyone know about this or how long the time out is supposed to be,,Also is there anyway to get the dam headlights to not go on when the key is in the on position,,ive tried shinning a light on the sensor,,turning of the light switch,,ect,,pretty annoying if you want to leave in the on position to reset the key,,and the batt rundsdown from lights being on,,lol
Old Nov 30, 2011 | 08:47 PM
IDK about bypass lock , But the headlight thing if you set park brake first they should not come on..
Old Nov 30, 2011 | 09:08 PM
chase2001's Avatar
thanks
Old Dec 2, 2011 | 02:36 PM
chase2001's Avatar
Problem solved,,Crank shaft sensor,,when bad agagin,,no charge part was under warenty from last replacement ya
BassNMan Mike
Nov 26, 2012 03:19 PM
04 dale jr supercharged
Nov 12, 2011 05:57 AM
warriormagee
Jul 11, 2011 02:05 PM
BocaReject
Apr 13, 2011 07:36 PM
Dave McFly
May 11, 2008 08:28 AM
