ticking from fuel pump relay
Old Jan 14, 2008 | 03:55 PM
full_monte's Avatar
Default ticking from fuel pump relay
Ok here's the problem. Car wont start. Starter is turning over no problem. I have a ticking noise comming from the fuel pump relay(when it's in accesory and when trying to start). The battery is strong. 1996 monte z34
Here's the things i've done to try and find the problem
1. i've checked for the fuel pump turning on and you can hear it huming so i take it it is working
2. i've jump started it just to make sure that it wasnt the battery
3. replaced the fuel pump relay(waste of $28)
4. i have spark from plugs
Any ideas??
Old Jan 14, 2008 | 05:47 PM
GrandPaDave's Avatar
Default RE: ticking from fuel pump relay
Back in the day, we'd pull the fuel line open to see if the pump is working.
If it was, we'd pull back the plug wire and inch to see if the wire sparks to the plug or engine.
But that was the old days....[sm=pimp.gif]
Old Jan 14, 2008 | 05:56 PM
04 Intimidator's Avatar
Put a fuel pressure meter on to see if you are getting pressure to the rails.
You could also disconnect the air cleaner from the throttle body and squirt some carb cleaner in there to see if you get any kind of firing.
Old Jan 14, 2008 | 06:25 PM
mickey's Avatar
better yet see if you can get someoen to pull codes on it.
you only need
fule
spark
air to make it run. and timming helps to but inreality if you have all three it is a matter of making them come in at the right time.
From what your telling me i would also crack opent he fule line at the intake and see if it is pumping threw there.
but be carefule it is a presurised system.
if you have fule and then you have spark
you need to make sure you have air.
Old Jan 15, 2008 | 08:04 AM
full_monte's Avatar
and what exactly do you mean by be careful cuz it's a pressurized fuel system. what kind of precautions should i take. never done it before. and since i have spark and sprayed carb cleaner. this is my last resort. thank for the help
Old Jan 15, 2008 | 08:30 AM
[align=center]
Fuel pump pressure & volume testing[/align][align=center][/align]
The fuel pump converts energy from the vehicles electrical system into pressure and volume, testing of which is covered in this final installment.
[align=center][/align][align=center][/align][center]
Obviously, a completely dead pump will keep the engine from starting. But how will a pump that's on its last legs affect performance? Any fuel injected engine that's difficult to start, idles rough, hesitates, lacks power under load or runs lean probably isn't getting enough fuel, and a weak pump may be to blame.
Install a fuel pressure gauge. Some systems provide a convenient pressure tap; it may be necessary to tee into the supply line on others. Start the engine to determine whether the regulated and unregulated fuel pressures are up to specs. Remove the vacuum hose leading to the pressure regulator. This unregulated fuel pressure indicates how much pressure the pump will deliver while the engine is under full-load, low-manifold-vacuum conditions.
Reinstall the pressure regulator vacuum hose. The fuel pressure should return to the manufacturer's idle specification. The regulator adjusts fuel pressure in response to changes in intake manifold vacuum and engine load. If the regulated fuel pressure is too high, the likely causes are a damaged pressure regulator or an obstructed return line. Low pressure can be caused by a clogged fuel filter or in-tank filter sock, a defective pressure regulator, a restricted fuel supply line or a weak pump. Eliminate all other possible causes of low pressure before installing a new fuel pump.
A deadhead fuel pressure test is similar to the stress test a cardiologist may one day ask you to take. It determines the fuel pump's reserve capacity by briefly asking it to deliver as much pressure as it can. To perform a deadhead fuel pressure test, pinch off the fuel return line while observing the rise in fuel pressure. This test should be brief.
A healthy pump may manage to jump from 60 to 90 psi. But if the pressure rise is minimal, either the fuel pump is weak or something is keeping it from delivering its all.
To prevent tuel percolation and aid hot- and cold-engine starting, fuel injection systems must maintain residual, or "rest," pressure when the engine is off. All systems lose residual pressure over time. Its just a question of how fast and how much before its a problem.
Since the entire supply side of the fuel system is normally pressurized, a loss of residual pressure could be caused by a leaking injector, pressure regulator or fuel pump check valve. Determining which involves isolating various parts of the fuel system, saving you the trouble of visually inspecting each component.
A ruptured regulator diaphragm will pass fuel to the vacuum hose and into the intake manifold. To isolate the regulator, pressurize the fuel system, then pinch off the fuel return line with pliers or clamps designed for this purpose. If the residual pressure continues to drop, the cause lies elsewhere. Repeat the same test to isolate the injector rail.
The fuel pumps internal check valve may be allowing residual pressure to leak into the fuel tank. To test, isolate the pump close to the fuel injector rail, then pressurize the system. No fuel pressure should reach the injectors or the pressure regulator during this test. If the fuel line pressure rapidly drops to zero, the residual fuel pressure is leaking past the fuel pump check valve, or through a fuel line fitting.
[b]An often overlooked, final test is pump volume. The simplest volume test involves opening the fuel supply line at the injector rail, then measuring fuel volume during a timed, power-on fuel purrlp test. This involves p
ReaperSS
Aug 29, 2014 11:35 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
Mdecourcey
Jun 27, 2013 08:20 PM
MJClemm
Dec 12, 2012 02:21 AM
JoeAsheville
Feb 16, 2009 01:05 PM
