taking out the plastic trim mold under rear window 85 monte carlo
Old Jan 18, 2010 | 11:54 AM
the_full_monte's Avatar
Default taking out the plastic trim mold under rear window 85 monte carlo
how to take out the back panel under the rear window so i can install custom 6x9
Old Jan 18, 2010 | 12:42 PM
Budsjlm's Avatar
there will be a bit of cutting involved with trying to install 6x9's unless you gett adapters to make them fit from underneath becuase the stock are like 4x10's
https://montecarloforum.com/forum/sh...ad.php?t=17156
here is a thread that has a few of the options....
but if i'm not mistaked you have to remover the top molding first then the two sides next to the seats the the botom comes out... it's been a while since i did/looked at mine so hopefully that helps you out
Old Jan 18, 2010 | 12:49 PM
Budsjlm's Avatar
Old Jan 18, 2010 | 01:55 PM
TheMonteMan's Avatar
im running the adapters in mine. i wouldnt bother trying to remove the rear deck.
MJClemm
Oct 9, 2022 09:13 AM
rmorman
May 17, 2012 11:10 AM
Steve518
Sep 26, 2011 04:39 PM
the_full_monte
Jan 18, 2010 11:19 AM
omb76
May 6, 2007 12:59 PM
