Syncing a Key Fob
Old Jul 27, 2012 | 12:16 AM
Monte02IntimidatorSS's Avatar
Default Syncing a Key Fob
Lost my last set of keys that had my old key fob on it and i dont quite know how to sync up a new one. It came with two when i got it but the one was never synced to the car. i have a 2002 monte SS
Thank You
Old Jul 27, 2012 | 05:16 AM
DE02Carlo's Avatar
Welcome!
1. Turn the ignition to ACC or ON and the radio to off. Do not crank the engine.
2. Press and hold the DISP button on the radio for at least five seconds until settings is displayed.
3. Press the SEEK up or down arrows until FOB PROG appears on the display.
4. Press the PREV or NEXT button to enter the submenu. The current selection will have an
asterisk next to it. BEGIN will be displayed.
5. Press the DISP button to start programming. When the message PUSH FOB flashes, press and
hold the LOCK and UNLOCK buttons on the first transmitter at the same time for 15 seconds. A
chime will be heard to verify the transmitter is learned.
6. Repeat Step 5 for each additional transmitter up to four remotes total. You do not need to press
the DISP button again, just press down the LOCK and UNLOCK buttons on the next transmitter
to be learned to a maximum of four transmitters per vehicle.
The mode you selected is now set. You can either exit the programming mode by following the instructions later in this section or program the next feature available on your vehicle.
EXIT (Exit Feature Customization Mode): This feature allows you to exit the vehicle customization programming.
To Exit:
1. Scroll until EXIT appears on the display.
2. Press the DISP button to exit programming. A chime will he heard to verify the exit.
Old Jul 29, 2012 | 12:53 AM
As far as using the radio goes. I have a different deck in there should that matter?
Old Jul 29, 2012 | 02:39 AM
You would need to have the stock deck. I think a dealer can still program it for you if you don't have the stock deck. If you do have one I'd just hook it up and program the fob then go back to the after market deck
ffej06montess
Dec 16, 2010 10:01 AM
ffej06montess
Jun 5, 2007 11:29 AM
Datafive0
Mar 12, 2007 02:29 PM
ralphtrent
Dec 24, 2005 01:01 PM
03SSdriver
Sep 16, 2005 10:43 AM
