Is it the switch??
Old Feb 28, 2008 | 08:16 AM
zk6216's Avatar
Default Is it the switch??
Dear Monte Carlo Fourm readers,
I have just oredered a new switch for my power windows about three days ago and it is finally on its way i was wondering if you belive it will fix the problem or not ... its the master switch on the driver side door it will put the passagenger window up and down but nothing happens with the driver side door when i hit the switch ..do you belive its the switch?
Old Feb 28, 2008 | 08:38 AM
04 Intimidator's Avatar
Default RE: Is it the switch??
Sounds like it would be it. I had a similar problem with my Blazer, but what I did was took the switch off and pinned out the connections with a test light. I was able to get the window to roll up and down so just bought a switch from the junkyard for $5 and it worked great.
Old Feb 28, 2008 | 09:55 AM
kweef's Avatar
i agree with dan
Old Feb 28, 2008 | 11:55 AM
RickCoMatic's Avatar
Before you just up-and-order a switch ... you should have done some preliminary troubleshooting to determine if it is ... in fact ... the switch. You can check the Fuse and the Power Window Relay. You can also probe the leads to the switch for +12 Volts and jumpered the wires to determine if the Motor was responding to seeing 12 Volts.
With Winter upon us ... a frozen window will blow the fuse or the relay could go bad from the cold making the Motor draw more current to operate a chilled window struggling to go up or down.
OK ... so, ... now we hope its the switch so you didn't toss that money on the fire. But, if its not the switch; check the relay and fuse because a lot of fuses get blown when cold weather lets frost and ice form in the channels making it difficult for the window to rise and lower.
Old Feb 28, 2008 | 08:19 PM
TheFullMonte's Avatar
I agree with Rick!1 more thing I've noticed on alot of them....most times when the switch looses the slight click that it makes when activated, its generally the switch. Its not an activated electrical click but a click in the internal plastic works of the rocker switch.
Old Feb 28, 2008 | 10:10 PM
zk6216's Avatar
Thank you all very much for your replies and yes i have done test before i replaced the switch unfourntetly the swich came in today but it was the wrong one =( so i have to send it back and they have to send me a new one which could take up to ten days =(((
Harlan2012
Feb 6, 2013 01:39 PM
soldout162000
Mar 24, 2006 12:34 AM
latts9923
Dec 16, 2005 02:10 AM
montecarlo1995
Jul 6, 2005 05:06 PM
kevin187
Dec 12, 2004 12:18 AM
