Supercharging
Old Apr 11, 2011 | 10:53 PM
Stickman03's Avatar
Default Supercharging
Hey guys I'm new to the forum and I was wondering if it is possible to take the supercharger off a Buick riviera with a 3800 in it also thank you in advance
Old Apr 11, 2011 | 11:49 PM
nitehawkjcb's Avatar
You need the whole top end and harmonic balancer then a tune
Old Apr 12, 2011 | 12:09 AM
Wilco's Avatar
Yes, you can! Don't forget the injectors, TB, belt, alternator?, PCM, etc. There's a write up somewhere around the forum which explains what you need to swap. Good luck and welcome to the forum.
Old Apr 12, 2011 | 10:46 AM
Stickman03's Avatar
Thanks guys will the PCM off the Buick work on my Monte Carlo and I need to use the block off the Buick and heads I take it
Old Apr 12, 2011 | 11:04 AM
zipper's Avatar
Not the block, but you will need the heads on up like already mentioned. Do a search on "top swap".
Old Apr 12, 2011 | 11:52 PM
Stickman03's Avatar
ok thank u guys and i will keep u all posted on my project this summer thanks for all the help
Old Apr 13, 2011 | 10:06 AM
The PCM won't work, you need a custom tuned one for your transmission (the gearing is 3.29, and the Riviera gearing is 2.93)
lbtheoneMC79
Oct 24, 2007 06:25 PM
marctapp
Jul 5, 2007 02:23 PM
KaptacularSS
Mar 31, 2007 04:42 AM
Angrywasp
Jul 15, 2006 07:25 PM
mcss01
Aug 17, 2005 03:08 PM
