The streak has ended
Old Jul 1, 2012 | 11:17 AM
aussiek2000's Avatar
Default The streak has ended
Well, I made it 108k miles before having to replace anything on my 2004 ls's engine (aside from Plugs,wires,belt). I put washer fluid in it the other day and I knew I smelled coolant. Today I popped the good and the water pump pulley and timing cover had residue on them. Started it up and after 5 mins it had coolant droplets all over the bumper and engine. At least it is a cheap part.
Old Jul 1, 2012 | 11:22 AM
good run!
Old Jul 1, 2012 | 11:36 AM
Sorry for the grammar. Using my iPhone. No power or cable due to massive storms.
Old Jul 1, 2012 | 11:54 AM
Are you doing it yourself, If it is the 3.4 it is really easy to change. I would recommend getting the part first so you can see how it comes out.
Old Jul 1, 2012 | 12:38 PM
I am a GM tech and have done dozens.
Old Jul 1, 2012 | 01:14 PM
That's a heck of a run! I think that deserves a huge CONGRATS and the good luck. But hopefully after this repair, you get many miles between repairs
Old Jul 1, 2012 | 02:53 PM
BlackRainSS's Avatar
Thats a damn good run 108k with no issues congrats man!
Old Jul 1, 2012 | 03:33 PM
Not too shaby
Old Jul 1, 2012 | 04:56 PM
I guess you can handle it then.
Old Jul 4, 2012 | 09:43 AM
Got it in the other day. Took a whooping 15 mins, $20 and no more leak.
