The streak has ended
Well, I made it 108k miles before having to replace anything on my 2004 ls's engine (aside from Plugs,wires,belt). I put washer fluid in it the other day and I knew I smelled coolant. Today I popped the good and the water pump pulley and timing cover had residue on them. Started it up and after 5 mins it had coolant droplets all over the bumper and engine. At least it is a cheap part.
That's a heck of a run! I think that deserves a huge CONGRATS and the good luck. But hopefully after this repair, you get many miles between repairs
I guess you can handle it then.
