steering wheel controls
Old Sep 4, 2006 | 09:52 PM
claude00's Avatar
Default steering wheel controls
Hi,
I have a 2002 Monte Carlo SS 3.8L Series II
A couple of weeks ago I took the steering column out because I was feeling a noise while turning at low speed. I did not find anything wrong with it, so I put it back on. Now the all the controls on the steering wheel don't work and the airbag light stays on. I checked all the plugs and wires. Everything seems to be in place. I don't know what else could cause this. Please help...
Thanks
Claude
Old Sep 4, 2006 | 10:29 PM
montejass's Avatar
Default RE: steering wheel controls
That "noise you were feeling" is more than likely the ISS=Intermediate Steering Shaft.
This may be a silly question, but did you check all of your fuses? Including the fuse blocks under the hood? Keep in mind there is a fuse panel on the passenger side as well as the driver side.
I would pull your battery power for 30 to and hour to let the PCM clear it's memory.
Old Sep 5, 2006 | 03:51 AM
mickey's Avatar
also don't forget to check your ground wires.
if any of this dose not work you might find that you pinched a wire in the column putting it back together. IF this is the case it might cut the power going to everything.
keep us posted please
Old Sep 6, 2006 | 06:59 PM
InTheIROC's Avatar
Might have ripped the airbag wire. When the column is disconnected, you should keep it straight to prevent breaking the wire. I don't know if that wire has power to the controls or not though.
enigmatic23
Apr 11, 2007 11:22 PM
Mr. 960
Feb 27, 2007 01:07 AM
we87
Dec 23, 2006 08:18 AM
krandall
Dec 19, 2006 09:37 AM
cain45
Jun 15, 2006 04:13 PM
