6th Gen ('00-'05): Stalls out and will not restart for several minutes or hours
Old Aug 9, 2014 | 11:54 AM
HarleyRider59's Avatar
Default Stalls out and will not restart for several minutes or hours
I was heading out to work this morning and my Monte just sputtered out and died in the middle of the road about 150 yards from the house. I tried to restart it and it would not, however after waiting for about 3 hours it restarted and I was able to get it back into the garage. I shut it off and tried to restart it and it would not run. After waiting about 15 minutes I tried and it fired right up. I do not understand this one for sure. About 3 months ago I had to have the upper and lower intake gaskets replaced. It is a 2001 SS with approximately 120,000 miles on it. Any and all help on diagnosing this problem will be greatly appreciated.
Old Aug 9, 2014 | 12:30 PM
Aaron0313's Avatar
When it won't hot start if you pull the plugs are they soaked in gas?
Old Aug 9, 2014 | 05:59 PM
Could be a clogged fuel filter..
I would start by checking the fuel pressure at the fuel rail...
My guess.. It just maybe a failing fuel pump.
Please keep us informed on what the fix is..
Thanks for joining the MCF Family!
Old Aug 9, 2014 | 06:07 PM
Habbibie's Avatar
Happened to my friend and his Grand Prix, turned out to be a failing fuel pump
Old Aug 11, 2014 | 05:32 PM
stevesssissy's Avatar
Awaiting Email Confirmation
my brother has a 98 monte carlo series 2 6 cylinder 3.8l and replaced the fuel pump and spark plugs fuel filter and still having the same issue??? its flooding smells of gas and can see the vapor. Turns over the first start of the day and runs for about five minutes then dead. Try turning over seems like it will start but doesn't??? any clues please what to look for??? ty
Old Aug 11, 2014 | 05:47 PM
Habbibie's Avatar
Old Aug 30, 2014 | 02:08 PM
Well i have replaced the fuel pump, filter, relay, and crankshaft sensor and this piece of junk is still doing the same thing......thanks for all your input on this matter, but i am tiring of being a parts changer. So far this thing has only given one code and that was for the crankshaft sensor. However it did not make a difference changing it either
Old Aug 30, 2014 | 06:42 PM
owens91's Avatar
Did u check the fuel pressure regulator?
Old Aug 31, 2014 | 08:58 AM
panpan's Avatar
One year ago I had the same problem (identical symptoms) and it WAS the crankshaft position sensor.
Did you replace it with a cheaper (china made) replacement ? Just asking.
If it still gives the same code, the replacement part could be defective, it happened on my wife's car with the MAF.
Old Sep 8, 2014 | 12:26 PM
The Fixer's Avatar
I had a similar situation, my 2000 SS would turn off right in the middle of the road with
about 74,000 miles. I went by other peoples symptoms and discover that the MAF & IACV had to change, problem gone !
Sorry for responding so late.
Old03SSDriver
May 15, 2015 08:32 AM
optic1
Dec 24, 2014 01:06 AM
1997Monte
Oct 13, 2014 10:44 PM
vincenti
Sep 5, 2014 12:08 PM
Tadcaster
Mar 28, 2012 10:02 PM
