Speedometer needle Jumps when stopping
Old Dec 15, 2011 | 05:31 PM
Dingo11582's Avatar
Default Speedometer needle Jumps when stopping
I have an 2006 Monte Carlo LT and sometimes when I stop the speedo needle will jump from 0 to 20-30 mph then settle back down to 0 again. It appears to be working fine in every other way it just does this every once and awhile. It happens as soon as the car comes to a full stop. Whats causing this and how easy is it to fix.
Old Dec 16, 2011 | 01:11 PM
mwjames's Avatar
i've never had the opportunity to work on a 06, but i would assume its the speed sensor on the tranny, it shouldn't be to hard to change.
Old Dec 16, 2011 | 01:30 PM
Jomao_o's Avatar
Jeesh, I hope it isn't your tranny.
I had similar symptoms on my 04. Changed BOTH at the same time so I was never able to pinpoint which one it was : MAF and IAC, but the rough idling stop.
BTW, mine went from rough idling, to stalling.
Old Dec 16, 2011 | 01:52 PM
mwjames's Avatar
it shouldnt be threatening to your tranny, but the sensor is on the transmission.
milrlyt
Jan 17, 2013 11:23 AM
03SSLE
May 8, 2012 09:02 PM
Vodka72
Aug 20, 2010 11:51 AM
weizie
Feb 24, 2010 06:16 AM
fwoggybaby
Sep 4, 2007 08:46 AM
