6th Gen ('00-'05): Speaker issue
Old Feb 23, 2016 | 06:36 PM
Nickstevens's Avatar
Default Speaker issue
I have a 2001 Monte Carlo w Onstar, stock stereo, stock amp in the trunk, but i have installed aftermarket speakers. I made this installation with the assumption that my back right speaker was blown however the new speaker sounds faint and almost nonexistent just as the stock speaker did. i am wondering what my cheapest option is to fix this issue? Is there is broken channel in the Amp? i do not think it is the wiring because i cut the wire right at the amp and wired it directly into the new rear speaker with no success, it sounds the same. Is there any way that I can install an aftermarket amp running the stock stereo? help please, thanks
Old Feb 23, 2016 | 07:50 PM
fatfig's Avatar
yes there is, just need to have little knowledge how to connect an amp. or you can just install a new amp and run new cables and not use the car lines.
Old Feb 23, 2016 | 08:07 PM
I went to best buy and the guy told me i cannot use an aftermarket amp with the stock stereo (with onstar) because it will cause technical issues with the door chimes and message center
