6th Gen ('00-'05): Something has fallen off my car!
Old Jan 11, 2014 | 07:10 PM
Sean_G's Avatar
Default Part of my Resonator has fallen off!
2004 Monte Carlo SS 3.8l
So I was putting on my pretty new exhaust tips I just got today and I needed to use a bit of force to work them on the exhaust. (Flowmaster 2.5" inlet 4" outlet) Then Something fell off my car from the underside.
Knowing that this probably isn't a good thing I investigate to find this laying under the car.
(Edit: I found the picture I was looking for and now know it is a resonator but still not sure about the droning sound or how to go about fixing this.)
I am assuming it is a part of the exhaust system but I was having trouble finding a picture of the exhaust that sows this part. As you can see this thing is quite rusty and has massive holes where I am assuming bolts used to go.So could someone help me out. What is this and how should I go about solving my dilemma?
Also my dad has been complaining about how the car drones quite loudly when I am idle and at low RPMs could this have been the culprit?
Now that I have found what it is anyone know of a good replacement I could order? I am guessing these affect the sound the car makes some what but any advice is welcome.
Thanks!
Old Jan 11, 2014 | 07:57 PM
That is just a heat shield normally mounted to the body. It is not really important at all, so don't stress. Heat shields are more of a PITA than anything else. They rattle. Although I'd want to make sure the heat shield around the gas tank is intact. That doesn't look like it.
Old Jan 11, 2014 | 08:02 PM
That is actually the heat shield to the resonator (which I believe is spot welded to the res). The res probably has a hole along the seam where it's crimped together.
I went through 2 aftermarket replacement resonators in less then 10,000 miles. My opinion, delete it. Replace it with a straight piece of pipe. I had a shop replace mine with a piece of straight pipe and never looked back.
Old Jan 11, 2014 | 08:17 PM
Sean_G's Avatar
Well thanks guys, glade this isn't a big problem lol.
monte-cristo
Jul 17, 2014 11:47 PM
Ricks 2006 SS
Sep 28, 2012 07:31 AM
Montelicious
Mar 9, 2011 08:26 PM
lucian*91
May 26, 2010 10:00 PM
nighthawk626
Jan 19, 2010 07:11 PM
