So winter is here, and things are wrong
Winter is upon us here in Denver, CO and I noticed that my rear windshield defroster isn't working. The light turns on when you hit the button and I visually inspected the wires in the rear windshield and found no breaks. Anyone ran into this and what was the fix? Really not sure where to look...and I can't figure out what fuse its on.
Also have a small chip in my front passenger side windshield. I really don't want it to grow so I'm wondering what you guys have done to fill small chips? I'm overloaded with do it yourself kits when googling.
I also don't have access to a garage so I'd have to fix it outside...in the cold, is that even possible? I would think the frigid air would prevent any resin from sealing on a windshield in this cold. Thoughts? Thanks guys!
Edit: ahhh I posted this in the wrong section, apologies! Can an admin move it to the right spot, thank you!
Your post was moved to the above Thread.
I hope that one of our expert Monte Member's can help your with your issues/problems > Good Luck <
This might help you solve your rear defroster issues:
https://montecarloforum.com/forum/fw...breaker-33233/
GoodZwell
Feb 21, 2013 08:22 AM
jpoogie84
31
Jan 8, 2012 06:29 PM
Cut Throat
Aug 10, 2009 12:57 PM
Krysden
Jan 11, 2008 04:49 PM
