smoke from front header 3800
Old Jul 11, 2013 | 11:01 PM
Mike6208's Avatar
Default smoke from front header 3800
Having white smoke coming from the front header, smells like oil when i stop after driving. would it be the head gasket or valve cover? or both?
Old Jul 12, 2013 | 05:57 AM
I doubt a head gasket, my guess is more a valve cover or who ever changed the oil last spilled a bunch.
Pop the hood and look around for where it's trailing from.
Old Jul 12, 2013 | 10:18 AM
Valve cover is a pretty common leak. I would suspect that first
Old Jul 12, 2013 | 10:38 AM
Blazed SS's Avatar
IT HERTZ
X2 on the Valve cover
Old Jul 12, 2013 | 10:46 AM
darksideSS's Avatar
There was actually a recall on our cars up to 2003 I believe for an issue related to this. It is likely the valve cover. The recall was to replace the spark plug wire guides with clips as the front valve cover was leaking oil onto the exhaust manifold and the wire guide was holding oil causing a potential fire hazard.
edit: someone else actually made a post with a link to the recall info, here is the link to that thread:
https://montecarloforum.com/forum/ge...v6-cars-13054/
Old Jul 12, 2013 | 05:03 PM
I'm not 100% certain, but I think the oil drip-age that resulted in the recall was due to people spilling oil on the engine and the removal of the plug wire guide was a "preventative" measure. Again, not 100% sure.
FYI - That wire retainer has been used since the mid-90's (or earlier). It even appears on the old 3300 v6.
Old Jul 13, 2013 | 07:46 PM
nitehawkjcb's Avatar
Most likely the valve cover gasket
Old Jul 14, 2013 | 07:38 PM
darksideSS's Avatar
Yes I am aware of the use of the wire retainer. But the recall was due to oil leaking from the front valve cover though yes some people did spill some oil and the guide would hold some of the oil then too.
Old Jul 16, 2013 | 09:59 PM
Mike6208's Avatar
i replaced the front valve cover gasket, cleaned the engine twice with degreaser, and still get smoke from the front headers, smells more like plastic now. could that be the oil thats baked on the header still coming off or do i have another problem here.
RattPack
16
Dec 30, 2015 04:09 PM
ZIPPY02
Dec 4, 2012 11:20 PM
gasman
Nov 9, 2011 06:32 PM
golfstud2k4
Sep 29, 2010 03:37 PM
