Simple TRAC light question
Old Sep 11, 2019 | 05:43 PM
excaliburken's Avatar
Default Simple TRAC light question
Going to replace both front hubs to get rid (hopefully) of the Service Tracc Sytem abd ABS light. My question is the previous owner let the problem go on for so long that the Trac Off light is burned out and half of the ABS indicator is burned out as well. How can I tell if the traction is on or off with the light being burned out on the dash?
Old Sep 12, 2019 | 10:54 AM
xpage's Avatar
You might want to jiggle the wiring harness, that was my problem with my trac light coming on, my hub replacement only worked for a week (as i moved the sensor wires). So if you move wires and it goes away you need to splice in new wires (they have a kit for this). But the hubs may be bad too or in need of replacement, depending on the mileage. As for telling if ABS is on or off, I'm not sure. But you can take the dash off an replace the light, dash removal isn't difficult just be careful.
Jokers1995
Aug 4, 2014 11:42 AM
vikesfan
Mar 27, 2014 09:25 AM
Jokers1995
Jul 31, 2012 09:11 AM
3xBlk'monte'ss
Jun 15, 2012 05:36 PM
oh3monteSS
Sep 19, 2011 07:11 PM
