SERVICE TRACTION SYSTEM and ABS Lights
Old Dec 28, 2009 | 05:53 PM
2004SS's Avatar
Exclamation SERVICE TRACTION SYSTEM and ABS Lights
Hey,
So recently, my "SERVICE TRACTION SYSTEM", "ABS" and "Check Engine" lights have came on - almost all at the same time so hoping they are all for the same reason(s). They stay on the entire time the car is on (whether in park or driving). Anyone know what could be causing this problem and/or what parts may be needed to replace? I have a 2004 Monte Carlo SS. Thanks!
Old Dec 28, 2009 | 06:10 PM
wnmech's Avatar
i had the exact problem with my 03 SS back in Sept. I took it to GM and paid for the diagnosis and they told me it was the electronic brake control module [ECBM]. They wanted over $1000 dollars to fix the problem. I took the car home and removed the connector from the ecbm and cleaned it with wd-40 which is located drivers side under hood forward lower part of the anti lock brake module and lightly tapped on the module with a hammer. I also cleaned the abs wheel sensors and the light has not come on again. The system is pretty simple except partscould be costly. If you can do a thread search on this problem my progress is dated back to mid sept.
Old Dec 29, 2009 | 07:34 AM
RocknSS04's Avatar
I've continually had the same problem. TYPICALLY it's the connector at the wheels. They get a little corroded. I use take it apart and put it together a few times them spray it good with WD-40 (which helps absorb moisture), they put it together wet.
I had that problem about a month ago. It would happen DAILY. I changed the oil and cleaned the connectors, and it hasn't happened since. It will again, and I've done it before. It's about a once a year thing for me.
Cost to fix? ZERO!
BTW, " I took it to GM and paid for the diagnosis and they told me it was the electronic brake control module [ECBM]. They wanted over $1000 dollars to fix the problem." What do you think THEY would do? Pretty easy money!
Old Dec 30, 2009 | 08:57 AM
2004SS's Avatar
Thanks for the suggestions. Probably going to try these out this weekend (if the snow will let up).
Old Dec 17, 2021 | 05:34 PM
Chrisgiantchevyguy's Avatar
Awaiting Email Confirmation
Originally Posted by 2004SS
Hey,
my 2001 monte carlo is doing the very same, driving me nuts. So I need the answer as well..
Old Dec 17, 2021 | 06:08 PM
Jeffs02rwdSS's Avatar
This post is 12 years old and the member hasn't been online since 12-30-2009.
mwmarshall
May 14, 2022 02:43 AM
michelob
Apr 16, 2014 10:05 PM
teamfbody
34
Aug 11, 2013 08:22 PM
Chris s
Jan 27, 2013 04:30 PM
Jokers1995
Jul 31, 2012 09:11 AM
