service engine soon
or by disconnecting the negative battery cable for about 15 minutes... but get it checked for any codes first.
has it been driving the same? everything the same as it has been?? perhaps you didn't put the gas cap on enough the last time you fueled up, creating a drop in vacuum pressure which will set off the light.
hey folks it also comes on to tell you time to change the ooil
if you have the stock raqdio in thecar you can do it threw it
OR
if you dont have the stock radio you can turn the key to on but do not start the car.
then pump the gas peddel 3 times with in 10 sec. i think it is.
then trun car off and restart it to see if it took
then scream adn throw a fit and try again till ya get it right.
it will go off this way but sioemtimes it is not the easiest way to get it to go out.
OR
TRobert
Aug 11, 2013 01:32 PM
srbecker58
Jun 16, 2010 09:50 PM
