serpentine belt issue
Old Jun 24, 2011 | 01:30 PM
dave countie jr's Avatar
Default serpentine belt issue
is this a tuff fix? still having belt chatter. driving me fruit! when the car is hot it shuts up? dont get it man. does anybody have a belt route diagram i can look up?
Old Jun 24, 2011 | 01:38 PM
There should be a belt diagram sticker under your hood.
Check all the parts that spin and see if you can find the noise?
Old Jun 24, 2011 | 01:40 PM
Tensioner ok???? Son had a problem with his buick
Old Jun 26, 2011 | 11:21 AM
i looked all through that engine compartment, no belt sticker chibi. had the abt changed twice tadcaster. changing that belt cant be that tuff, is it?
Old Jun 27, 2011 | 09:37 AM
TheMonteMan's Avatar
depends on the car. i believe the ls4s require a special tool to do it.
Old Jun 27, 2011 | 05:27 PM
Try googling a diagram and/or instructions on-line pleanty of info out there on the belts
Alos I did a search for Serpintine belt right here on MCF and there where some threads but did not know idf they would pretain to your car. Even a U tube instructional link
Old Jun 30, 2011 | 10:29 PM
kc2kth's Avatar
The belt on the 3800 NA used to take me about 10 minutes to swap with a 3/8" ratchet to move the tensioner. Since I put the SC engine in I have an extra belt to change and much less room to change it in, so I haven't tried.
Old Jun 30, 2011 | 10:39 PM
70monte1's Avatar
My belt is starting to make noise on startup on my 2004 with the supercharged engine. I'm not sure which belt it is or if its one of the tensioners. The belts look good so I'm assuming the tensioner which I don't know how hard these are to do on the supercharged cars.
Wayne
moonlitmagik
Dec 6, 2023 10:53 AM
yellow montecarlo
Apr 9, 2013 11:10 PM
KWJR86
Apr 8, 2012 09:30 PM
Jack The Ripper
Jul 2, 2010 08:21 PM
rockin dude
Jun 12, 2010 08:43 AM
