Seized ignition cylinder
First just because there is a tsb does not mean this is a chronic issue. Also, gm uses this same ignition switch and lock cylinder on multiple models. I have 3 of those in my drive way and a ton of friends with then, never an issue with the ignition switch (but there are others out there that have had issues).
Lastly, this tab has nothing to do with the recall on these cars. The recall is claiming the weight of stuff people put on their key will cause the ignition to slide into the off position (in the long history if this ignition switch, I never heard of that happening).
There is a lot more to this discussion.
The idea of wd is not to clean the cylinder, it's to lubricate it. You should use a lubricant from time to time on all lock cylinders on your car to avoid them seizing over time.
I don't like WD because dirt sticks to it like a magnet. The PO cleaned the engine bay with it, it's amazing what sticks to it. WD is also not a true lubricant, it's a water displacement, I could try some lithium grease after cleaning it with elec. cleaner. Thanks for the diagram.
Everyone's sample sample group with this ignition switch design does differ. I have 3 cars with it, zero issues. I easily know another 5-10 people (local friends and family) running cars with this same ignition switch set up (and many cases have put a tons of miles on these cars, one of them is over 230k miles) and no issues. My offline sample group has been problem free.
As for the wd, I know it's not a true lubricant, but It has many applications to work as a libricant. I know it stands for water displacement and the 40 is the 40th formula/trial before they made it a retail product. I would never use it to clean an engine bay. I don't know anyone who has used white lithium in door locks (hinges yes, locks no). That's a bit thick of a lubricant for lock cylinders. If you really don't want to use wd for your locks, then check the parts store for other thin lubricants (there might even be something recommended for lock cylinders).
Handle is off, screw is out, plate is off. The console does not have enough play because the shift rod is stuck in park. The front of the cut out of the console cannot get past the rod. It seems physically impossible to get the console off without touching the shifter rod.
UPDATE:
I got access to the detent finger adjuster through the front cup holder. Unfortunately, unlike the the impala, adjusting the detent finger did nothing to help.
I also noticed a static noise comes from the front speakers when a battery is connected(full charge). Would this be a bad relay/ground, or a faulty ignition?
BTW, Where are the bolts in the lower console ? I think I may be able to remove the whole console in one swoop.
Thanks for all the help so far guys !
Brandons monte
05-21-2014 10:49 AM
05montecarloyo
08-08-2012 07:02 PM
