security light
Old Sep 20, 2006 | 01:15 AM
okds650's Avatar
Default security light
The security light keeps coming on and the car won't start, have re-set thru radio several times to make the car work, but later the light will come on again. Sometimes not for a day or so, but it still happens. 2001 Monte Carlo LS 3.4 -- need help!
Old Sep 20, 2006 | 01:57 AM
schroederdion's Avatar
Default RE: security light
i've had something simular on an impala once.... we brought it to the gm shop, but the car didnt act up for them. So they replaced the car's computer ($500 cdn) and we never had the problem again.
for us... we'd be driving, then the passlock light came on. (security light), and then it cut out all power to the light's, but the car still ran.
Hope this help'd...
Old Sep 20, 2006 | 07:47 AM
04mcss's Avatar
sounds like your BCM is going bad.
Old Sep 20, 2006 | 04:52 PM
bbengineer's Avatar
I would check the following:
1) Try using the spare key and see if that works. As the key gets worn, the ignition cylinder has trouble sending the correct code to the BCM
2) If that doesn't work, it sounds like the ignition switch/lock cylinder is going.
3) There is an off chance that the BCM is going, but you typically see other weird behavior as the BCM goes
BBEngineer
RonKennesaw
Jan 5, 2015 04:49 PM
EbonyChevyMama
Jan 1, 2015 06:41 AM
lolligirl56
Oct 19, 2009 10:16 PM
poynter32
Feb 10, 2009 10:41 PM
