seat belt conversion
Old Oct 26, 2009 | 08:07 PM
Monte SSV's Avatar
Default seat belt conversion
Would like to convert my factory 3 point harness drivers side seat belt to a 4 point harness. Has anyone done that and\or does anyone know of or can recommend a bolt in application to my existing anchors? Any help would be appreciated. Thank you. Bahdeets/SAM B.
Old Oct 27, 2009 | 05:32 PM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
I was thinking about doing the same thing with racing seats and without a roll cage I was thinking about taking out the back seat and extending the harness to where the factory back seatbelts would go. Other then thaT I would assume you would need a roll cage of some sort to do it.
Old Oct 27, 2009 | 05:50 PM
Budsjlm's Avatar
i have seen where people have actually used where the seat bolts to the body to attack thiers
Old Oct 31, 2009 | 11:08 AM
Monte SSV's Avatar
Another question has arisen. I understand that the seat belt is tied into the PCM or BCM and can not be altered without effecting the ABS system. Any advise would be appreciated. Hate to change my seat belt confirguration and have my ABS not work.
Old Aug 21, 2010 | 05:41 PM
Monte SSV's Avatar
Well guys have figured out my problem. Remove the back seat and Corbeau makes a 3 point retractable harness that bolts right into our cars. Perfect solution. I have my back seat out. Carpeted everything - and am using the lower 12mm original bolt for the retractable mechanism. Also the seat belt light can be jumped or bypassed very easily and no light on the dash.
Old Aug 22, 2010 | 01:03 AM
Budsjlm's Avatar
i was just gunna sat just wire it a close loop that way it thinks it's belted and i have herd of people actually using the seat bolts for there anchors
Sebastian Thonet
Sep 3, 2014 11:17 AM
cali2000ss
Feb 7, 2008 12:24 AM
BeachBumMike
Jun 11, 2007 11:57 AM
zipsayain
Jun 4, 2007 05:12 PM
Laserblue06ss
May 8, 2007 05:44 PM
