Running Cold
Old Dec 21, 2007 | 08:01 PM
Epic's Avatar
Default Running Cold
The last couple of mornings, I've gone out started it up and let it sit for a few minutes like usual to warm up. It hasn't been very cold lately but i've noticed that within the last few days even after I let it sit for abit the temp gauge is at the bottom (the needle is far left), even after I drive to town (about 20 mins) it'll only go up to the quater mark on the temp gauge. It usually sits at half after a good drive, this "problem" with it not warming up only started a few days ago.
I've only had the car for a few months so I'm not sure what has been changed, I have winter coolent in it, and it's been working fine up until now. It's only been around the -10C (14F) mark so it's not very cold. I had to replace the battery last week due to it being to weak to start the car, do monte's just hate the cold or what should I look into? I was thinking it was a sensor, but why would it just go all of a sudden the other morning? I've been using the block heater lately and while it makes it easier to start it still is cold according to the temp gauge.
Old Dec 21, 2007 | 08:10 PM
scc24540's Avatar
Default RE: Running Cold
sounds like you need a thermostate bro. those things fail in a instant is probably stuck open. its a 5 dollar fix
Old Dec 22, 2007 | 03:25 PM
04 Intimidator's Avatar
I'll concur with the thermostat being stuck open. They get gummed up sometimes. I recommend just droping 10 bucks and getting a new one.
Old Dec 24, 2007 | 02:38 PM
Epic's Avatar
Okay, Is this the same thing your talking about?
http://www.pfyc.com/pc/WB3003/MCUNDE...ermostats.html
If I went with the 180, could I use it at the moment where it is winter and cold out? or is that thermostat just a summer time thing? (It does get very cold some days here) I was going to get this for the summer anyways.
Old Dec 24, 2007 | 03:08 PM
kweef's Avatar
i have a 180 t stat and its 16 outside rights now lol and yah thats what ur lookin for but i would just go to like advanced auto parts or sumwhere to get it and a new gasket for it
Old Dec 24, 2007 | 03:24 PM
RocknSS04's Avatar
Ditto. DO NOT PUT IN A THERMOSTAT COLDER THAN 180 DEGREES!!!!! GUARANTEED it will throw a CEL code.
Unless you have a good reason to put in a colder thermostat, stick with the 195 deg' thermostat.
Old Dec 24, 2007 | 04:13 PM
Epic's Avatar
ORIGINAL: RocknSS04
Are there any advanatages to the 180 stat?
Old Dec 24, 2007 | 04:28 PM
RickCoMatic's Avatar
I'm sure glad I read this Thread. I had planned on installing a 175 Degree or Cooler Stat for the Summer because the wife sits in traffic that crawls out of Boston during the evening rush hour.
That, and because back when I had a Peugeot 505S ... the Cooler Stat helped with controlling the chronic leak-by that occurs when the XN6 Engine got overheated. That Engine was a Big Inline-4 with replaceable Cylinder Liners with water jacket all around them and the base liner seals leaked if the engine overheated.
Am I going to be OK if I do want to run cooler than 195-Degrees and step down to the 180-ish thermostat when the Summer Months roll around?
Old Dec 24, 2007 | 06:49 PM
RocknSS04's Avatar
A 180 will work just fine. Many of us here have them. I REALLY notice the difference this time of year, as the heater is MUCH colder. On the other hand, I'm looking forward to having the colder t'stat in the summer when it would usually climb to that 200 mark and beyond. My tran's climbs beyond that, and I'm hoping that will help it stay down around 200-210. I've seen my trans temp climb to 230.
Merry Christmas to you all.
lostagain
Feb 17, 2015 03:43 PM
umbreonix
Feb 9, 2014 05:15 PM
montejass
Apr 9, 2006 04:56 PM
hersheybun88
Oct 11, 2005 11:34 AM
04MonteLS
22
Aug 5, 2005 05:20 PM
