Daytime Running Lights - Help!
Old Jan 25, 2005 | 07:59 PM
hersheybun88's Avatar
Default Daytime Running Lights - Help!
Hello everyone, I'm looking for any advice on how to dissconnect those annoying Daytime Running Lights/Auto On Headlights properly! Can anyone help me?[:@]
Old Mar 7, 2005 | 02:29 PM
ineedamontecarloss's Avatar
Default RE: Daytime Running Lights - Help!
i dont think u can in my knowlege i think its a timing thing doing it so i think youre out of luck
Old Mar 8, 2005 | 03:44 PM
montejass's Avatar
Actually, at least on the newer MC's if your sitting in the driver seat there is a photo sensor located just left of the defrost vent on your dash that controls when your DLR's go on and off. I simply moved that sensor to a dark area in the dash. I have heard of other taping off prongs on the DLR relay to making a little rubber cap to cover the sensor. Once you hid your sensor the DLR's will still remain on till you turn on your parking lights. I always run mine with the parking lights on with my fogs running. I think it looks much better that way. I posted a how to get to the photo sensor somewhere here. I'll look it up and post a link...
TVW
Old Mar 8, 2005 | 03:49 PM
montejass's Avatar
DLR link
Here is the how to on moving the sensor.
TVW
Old Jul 25, 2005 | 11:27 PM
Darkness98's Avatar
Can you not just remove the DRL fuse from the fusebox?
Old Jul 26, 2005 | 11:27 AM
Yes, you can IF you have a 1999 or older Monte! I have a 2003 and on the 2000 (I believe) and newer models, the "check engine light" will come on. I had a 1999 Monte and all i had to do was take out that fuse for the DRLs and it will put the kabash to the DRLs AND it will also dissconect the auto on headlights. Good luck if you have a newer Monte! Place a post here if you do and find a way to dissconect those pesky things!
Old Oct 11, 2005 | 11:34 AM
Here's a linOrdering information for the plug and play kits is here:
http://naioa.com/impalabb/viewtopic.php?p=57817#57817
k on disconnecting the DRLs and the auto on headlights!
00codyss
Jul 5, 2019 01:44 PM
06BlackSS
Apr 20, 2019 01:26 PM
inssanity21
Oct 22, 2008 09:09 PM
Cowboy6622
Aug 1, 2007 08:54 AM
jzeiger07
Jun 23, 2007 07:24 PM
