6th Gen ('00-'05): RPMs shoot up when idling and driving, and makes the car accelerate on its own.
Old Jul 17, 2014 | 08:58 AM
xxfallen-comradexx's Avatar
Awaiting Email Confirmation
Default RPMs shoot up when idling and driving, and makes the car accelerate on its own.
Pretty much like what the title says. 2004 SS Supercharged L67, about 134000 miles. When it idles the rpms will shoot up from anywhere from 500 to 4000, and it will do the same while driving, making the car accelerate. Any ideas as to what this could be? It does have a vacuum leak that needs to be fixed and I wonder if that may hav esomething to do with it.
Old Jul 17, 2014 | 09:29 AM
03SSLE's Avatar
A vacuum leak can cause an erratic idle as you describe. I would eliminate the vacuum leak and see if that resolves the problem. If it doesn't I would check the MAF sensor wiring. Still not fixed? Test and clean the MAF sensor. If the idle is still erratic I would then check the IAC.
dns
Oct 18, 2014 04:56 PM
southerncash
Feb 28, 2010 12:47 PM
Absolutpolack
Feb 23, 2010 07:25 PM
PINKFLOYD_
Jun 6, 2009 12:16 AM
mattilus2121
Feb 26, 2009 02:33 PM
