Rolling backwards at the light and rocking when I stop
Old May 2, 2011 | 02:15 PM
Curtis24682007's Avatar
Default Rolling backwards at the light and rocking when I stop
Does anyone know what it means when my 2001 monte SS rolls backwards on slight hills at red lights? Also when I put my car into park it rocks before it stops. Just wondering if it is this is a transmission problem or is this how these transmissions work. No problems shifting that I can tell. Any ideas would be helpful.
Old May 2, 2011 | 02:33 PM
if this is on hills its pretty normal, just use the brakes when waiting for a light to not put stress on your transmission, and when putting it in park you can use the parking brake also
Old May 2, 2011 | 03:06 PM
Budsjlm's Avatar
creeping forward or backward in park is just the parking prawl lining up to hold the car in place, if it can be pushed around in park you have a big problem
Old May 3, 2011 | 12:42 AM
Thanks guys, I was just wondering if that was normal because I had never had a car that did that. Where is the parking prawl located and does your car creep back and forward too?
Old May 3, 2011 | 07:56 AM
03SSLE's Avatar
I haven't noticed any rolling backwards at red lights, but when I first got the car I did notice (when I didn't use the parking brake) it would creep forward a little after putting it into park. Since then I have been applying the parking brake prior to shifting into park and it doesn't creep forward anymore.
Old May 3, 2011 | 08:10 AM
Budsjlm's Avatar
i don't have a newer gen monte but i have an olds intirgue that has the same transwhen i put it in park most times than not it well creep forward a couple inches and be set
Old May 3, 2011 | 09:34 AM
I use the parking brake when I park so there is no roll, on a hill I hardly ever roll backwards unless it's an extremely steep hill.
Old May 3, 2011 | 11:12 AM
Ok thanks again guys, I will start using my parking brake. I just thought that was was weird and wanted to see what everyone else's monte was doing. The hill is kinda steep but I use to have a buick and it would not move on the hill I was just wondering if there was a problem.
Leprechaun93
Mar 21, 2013 09:26 AM
racegirl120
Aug 23, 2012 03:11 PM
Alan Lintz
Dec 26, 2011 09:33 AM
jim1405
Nov 30, 2010 08:57 PM
Sep 8, 2008 08:27 AM
