right side oil leak
Old 03-07-2012, 07:06 PM
i had a seroius leak and it was some gasket thats in above where your oil filter screws in ...i dont know what its called but it actually there is a seal in the thing the oil filter screws in to....dont know if this willhelp any....
Old 03-07-2012, 07:09 PM
Cool oil leak on driverside under car
it only seems to be leaking while its running ...i just notice it today and taking it up to a buddy shop so i can put it on a lift....some times it pays to have friends
Old 03-07-2012, 08:58 PM
goingforgold's Avatar
Well I found the problem. I took the pully off the water pump and it was leaking at the weeper hole. It gave the appearance of oil because it was collecting oil grime from the block and by the time it got to forming on the belt it looked like oil. I don't understand why the pressure didn't bleed down when I put a pressure test on the cooling system. I also have a coolant leak at the top rear left side. I can't seem to locate the problem. I think I'll have to remove the TB so I can get a look at the therm. housing and anything else in that area.
TMoney
10-02-2013 08:03 PM
BlackRainSS
04-10-2012 06:34 PM
blackmonte781
09-14-2011 08:46 PM
kanianic
01-01-2011 07:03 PM
Quick Reply: right side oil leak
