Resetting Tire Pressure & Oil Change Monitors
Old Nov 1, 2005 | 04:26 PM
c1benny's Avatar
Default Resetting Tire Pressure & Oil Change Monitors
Wondering if anyone knows how to reset the oil change and tire pressure monitors without using the factory radio on a 2003 monte. I am going to replace the head unit, but still have these outstanding obstacles that need to be taken care of before doing so.
Thanks for the help!
Old Nov 1, 2005 | 04:34 PM
mickey's Avatar
Default RE: Resetting Tire Pressure & Oil Change Monitors
due a serch for it on here there is tons 0of info on here for it
Old Nov 8, 2005 | 01:22 AM
chevy_jj's Avatar
the only way to reset them otherwise is to use a gm tech 2 scanner that the gm shop has. not available to the public. you could change the radio but when you change or rotate tires and change oil you would have to take it in to have it reset. if your dealer mechanic is nice enough they may do it for you.
Old Nov 10, 2005 | 12:06 PM
z34phoenix's Avatar
go to mymonte.com we have tech articals over there and they cover the procedure for you to do it
dcnaser
May 19, 2013 01:55 PM
lu9103
Feb 26, 2012 08:11 PM
01montesf
Nov 9, 2009 02:41 AM
God_Bot
Jun 6, 2008 07:25 PM
Great White North
Mar 10, 2006 01:33 PM
