Is this a repair for the steppor motors for the gauge clusters?
Old Sep 3, 2013 | 01:29 PM
tj4ndirish's Avatar
Default Is this a repair for the steppor motors for the gauge clusters?
I have a 2005 Monte, my speedo went out 2 or 3 years ago. I tried changing the steppor motors last year or so. That worked for 2 days and it went back to not working, then the temp gauge went. When I looked, I saw no recalls on this issue. Today I looked for information on changing the a/c evaporator and found this:
http://www.justanswer.com/uploads/Bl...ter_policy.pdf
I see a couple of dates on it, I also see that the 2005 Monte is listed and to be repaired or whatever. So, can I call my dealer and tell them I found this and I expect them to repair my gauges?
Thanks!!
Old Sep 3, 2013 | 03:41 PM
First I'd be curious when you cluster was manufactured.
Second, I don't think this will be a freebie from the dealer unless your Monte is still under warranty. The TSB makes no mention to extending the warranty.
Third, you said you replaced a stepper motor once. If it can be found the cluster was tampered with, any warranty would probably be void anyways.
You might be best sourcing another cluster. I believe a member here (I think TMoney) has one for sale in the classifieds section.
Henderson21
Jan 7, 2014 01:41 PM
PUNK LIFE
Jun 7, 2012 01:42 PM
trailrider894
Sep 18, 2009 11:40 AM
zipsayain
Jul 7, 2006 10:53 AM
