Removing front axle
Old May 16, 2006 | 10:22 PM
reswob's Avatar
Default Removing front axle
I'm trying to help my friend fix his '98 Monte Carlo Z34 and we need to replace the passenger side front CV axle. I removed the brake caliper and there is still a piece holding the rotor on, it's a torx bolt[:@] Does anyone know what size torx-driver is needed or know where I can find a listing of bolt sizes? Also, would an axle from a late 80's Buick Regal fit the Monte?
Old May 17, 2006 | 07:30 PM
bigblok75's Avatar
Default RE: Removing front axle
the torx size you need is a t-60. It will be 1/2 inch drive and sometimes requires heat to get the bolts loose (in other words an impact or a BIG breaker bar). Sorry, not sure on the regal axle fitting? If I had to guess I would say no but I'm not sure.
Old May 20, 2006 | 02:26 PM
InTheIROC's Avatar
You shouldn't need to remove the rotor to get the axle out.
Old May 20, 2006 | 02:53 PM
reswob's Avatar
ORIGINAL: InTheIROC
Oops, too late now. Oh well, it needs new brakes anyway. Thanks for the help guys!
kcmarkviii
Oct 7, 2013 08:44 PM
jacc
Jul 22, 2013 09:57 AM
jasonsmith
Feb 15, 2012 08:11 PM
Montelicious
Aug 5, 2011 09:30 AM
MonteDriver
Mar 10, 2010 07:15 PM
